LImp mode
CAMVE
Peterborough
Hi all,
I'm new to this forum and was wondering if anyone could help? The other half has just come home and said 'the car is knackered'. I've just had a quick look and the problem is, the car will only do 40mph, no acceleration, the ESP light is on on the dash and the glow plug light flashes on the dash also. The car is a A4 2.5TDI 2005 and only done 67000miles. She loves the motor, so any help would be much appreciated. Thanks.
You need to get a diagnostic done. There will be a code/codes logged in the ECU which will point you in the right direction.
Happened to mine last year.Water has built up in the scuttle tray where the ecu and battery sit.This has leaked down behind the brake,throttle,clutch pedals(check up behind for wet carpet) and caused a short on the throttle sensor.My local audi specialist sorted this out for me.
827
15
6K
