My '58 A3 8P 2.0 CR140 TDI (with Bluefin) has been 100% reliable until a week ago when it came up with error P2563 (Turbocharger Boost Control Position Sensor Circuit Range/Performance) but the car still ran fine. Then 2 days later, the DPF light came on (error P2002) and forced regen doesn't make any difference. Shortly after, the car lost most of it's power.
I've taken it to a couple of garages - the first said (without looking) it would be the DPF being blocked and they would gut the DPF and map it out of my BlueFin.
The 2nd garage put a hand-pump on the actuator - this didn't hold any pressure and they believe the diaphragm is gone so I will need an actuator repair kit. From my research on this forum, this seems to be highly likely so I believe this is the problem.
Can anyone please answer a few quick questions for me?
1) Is the DPF issue likely to be related? (if not, is it likely to be a blocked DPF or faulty sensor?
2) Will it do any damage to keep driving the car gently at <2000RPM.
3) How difficult is it to repair the actuator? (I do a lot of work on cars but never attempted this).
4) If i repair the actuator myself, can I then drive it somewhere to have the "Basic Settings" adjusted in ODIS/VAGCOM/VCDS.
Many thanks!
EDIT: Forgot to mention that the glow plug light is flashing constantly (since the original P2563 fault) and that the throttle pedal does nothing after about 25% of the way down.
Many thanks!
