Hi all, asked about this car in another part of the forum but thought id post the results in the correct forum.
Its a A3 2.0 TDi SE , BKD engine, 140 BHP 2004 with 108,000 on clock, full history 2 owner car
Problems it has, it wont idle properly (jumping about all over the place, but only when the engine is up to temperature, doesnt do it when cold) and secondly it wont cruise between 2000 and 2500 revs it starts spluttering and lurching.
Did some logs and the results below, only ones that look off are to do with the injectors, mainly the deviation
Friday,06,March,2015,20:58:00:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: VSSZZZ1MZ4R008425 License Plate: XX04XXX
Address 01: Engine (03G 906 016 G)
20:57:44 Group 013: Idle Stabilization (Injection Quantity Deviation)
-1.51 mg/str Injection Quantity Deviation Cyl. 1
1.39 mg/str Injection Quantity Deviation Cyl. 2
0.71 mg/str Injection Quantity Deviation Cyl. 3
-0.59 mg/str Injection Quantity Deviation Cyl. 4
20:58:36 Group 017: Readiness Code (EOBD)
00000000 CARB Mode 01 DATA A
01100110 CARB Mode 01 DATA B
10000000 CARB Mode 01 DATA C
10000000 CARB Mode 01 DATA D
20:58:44 Group 018: Injector Status
0.0 Injector Status Cylinder 1
0.0 Injector Status Cylinder 2
0.0 Injector Status Cylinder 3
0.0 Injector Status Cylinder 4
20:59:03 Group 023: Injector Switch Time Deviation
-26.0 Switch Time Deviat. Cylinder 1
-41.0 Switch Time Deviat. Cylinder 2
-34.0 Switch Time Deviat. Cylinder 3
-46.0 Switch Time Deviat. Cylinder 4
21:00:48 Group 090: EOBD/OBD-2 Exhaust Gas Recirculation (EGR) I
861 /min Engine Speed (G28)
0.0 mg/str Injection Quantity
250.0 mg/str Exhaust Gas Recirculat. (spec.)
00000000 Status Control Deviation
Friday,06,March,2015,21:03:10:33490
Readiness Status: 00000000 01100110 10000000 10000000
MIL Status: MIL OFF
Comprehensive Components: Failed or Incomplete
Fuel System: Failed or Incomplete
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
Any ideas whats going on?
MIL Status: MIL OFF
