have got steering rack replaced yesterday, old unit has rust inside, it was a bit noisy but not leaking. problem is that after it took second 1litre bootle of steering fliud it got suspicious, in the end i spotted than fluid is slowly dripping on floor, after more inspection i found that all hydraulic fluid is trapped in new steering rack's both rubber booth where inner tie rod ends is located. rubber boots are expanded and are hard on touch, photos attached. please post any ideas. i have worked on it together with mechanic, it took around 8hr just because a lot of screws and bolts were seized, but job were done clean. thanks
