Head/side light question
WelshBoa
Hi
My car has the self levelling headlights (xenons?) but has the standard sidelights.
Bulb has gone but not sure which bulb type it is, and whether these are a pain in **** access wise to fit and whether one particular side is more difficult to replace?
Is it a cab, or saloon/avant?
If it's a saloon/avant then the sidelights for xenons are H6W
Also you need to remove the lights all together to change bulbs.
It's the saloon... You have to remove whole unit do you?
You can change some of the bulbs in situ, but as it's only 2 screws to remove & 2 to loosen, it's easier just to pop out the headlamp.
Here's a little how to I made when I first got the car before fitting my xenons. The bulbs are different to what you have, but it shows you how to remove the light units so should help you out.
If your planning on doing this in front of the car because your lazy and can't be bothered walking all the way to the kitchen table (like me) get a nice big piece of cardboard.
There are 4 Torx bolts/screws holding each light unit in place.
There are two on top that are clearly visible
One down the left hand side by the radiator hose
One down by the power steering reservoir
The two on the top need to come out completely, but the two at the bottom only need to be loosened off.
There is a little plug that holds part of the loom to the unit that you have to pull out also that is on the inside
Once this has been done the unit will slide out a few inches to allow better access to the main loom plug.
Once out a few inches you can then get a flat headed screwdriver into the release hole for the loom which needs to be pulled off the unit to fully pull it out
The drivers side involves a little bit more as you have to remove the cold air feed pipe, but this is only a case of removing two screws that you can see below. Once these have been removed you simply pull the two pieces of plastic pipe up, and the top piece just clips into the air box.
Also be mindful of the bonnet release cable when removing/refitting the drivers side as it passes along the top of the light unit
Then there are two on top again
One on the inside where you can also see the small loom plug needs to be pulled out
And one down the back near the air box
Now remember that piece of card I spoke of earlier well this is where you use it. Stick it on the floor so you can put the light unit down without damaging it.
There are two metal clips that need to be popped open so you can remove the plastic covers. You can use your fingers so don't be tempted touse a screwdriver, or similar as you will most likely break them.
The indicator bulb holders simply twist then pull out. It'sat this point that you need to put a clean pair of gloves on as the oil, dirt,and grease on the gloves you have on will just damage your nice new bulbs.
When you take the plastic covers off you will notice that the sidelight holder is hidden behind the leveling motor, but it simply twists out of the way
Once you have replaced the bulbs its time to fit the light units back into the car which is pretty easy you simply push them back in so that the clips sit into the bottom of the light and around the lower screws.
If the lights won't simply push in with minimal effort then they aren't lined up properly, so don't force them just pull them back out a bit and try again. Once in you just have to push the loom plug back on until it clicks, and clip the little loom back onto the side.
Reactions: BakPak
That's a great tutorial manny thanks.
However reflecting on previous attempts at doing basic car maintenance, I fear my cack handiness would result in further £££
Ps if I do attempt this do I need to realign headlight beam etc even with the self level motors?
It's an easy job mate, and not that I know of as the self leveling works off sensors on the suspension. Changing the bulbs shouldn't effect the light beam.
Ah right yeah that's my knowledge of cars summed up! Lol
631
704
