Yep that's what I mean. Each door took about 20mins I just took them all off and did all together. Just be careful when unclipping the cards off....I snapped one but not a big issue as the screws held all back together and doesn't rattle. There is a guide just follow that.
Puddle lights they are called.
You'll be able to see that too once you remove the door card. If you like you can check now to see if there are holes there (most likely not) so you will probably need to cut them yourself.
Trups will also be able to supply the stuff for that, too. Trups: http://www.audi-sport.net/xf/members/t8ups.59066/
