May be, but according to the Audi documentation the normal Cruise Control only uses engine braking.
The documentation may say that but we know of many undocumented features and also documentation errors - just look in the Little Surprises thread.
If it is being used with a manual gearbox you can get more engine braking by staying in a low gear. With an s-tronic gearbox, as I said in my earlier post, it will change up automatically and therefore give less engine braking.
Well it doesn't do that on mine. It will happy change *down* to increase engine braking but mine also uses 'cruise braking' if needed and I'm not the only one with a car that does this. Changing up a gear whilst going downhill would just lead to runaway train syndrome if the brakes aren't applied (regardless of whether applied by the driver or by the car itself).
Personally I don't think that the will be a difference between different models fitted with the same basic cruise control other than between manual gearbox and s-tronic gearbox or the fact that one type of engine may give more braking effect than another.
....but this thread has already shown that there is a difference and that is what we are trying to investigate.
The difference with ACC is that it does most definitely use the braking system to slow the car or actually stop it if necessary no matter which gearbox is fitted. If fact the ACC does seem to work better with the s-tronic that the manual because when it does stop the car in a traffic queue it always selects first gear ready to move away and changes up as necessary depending on the speed of the traffic with the driver having to do anything.
ACC is not at issue here. It's better than normal cruise control; no argument from me there.
ACC will help stop you crashing into the car in front; normal CC won't. Extending that scenario, the question here is what defines whether normal CC set at 50 when going downhill will crash into the car in front at 50 or allow the car to gain speed over the set 50 and do the deed at 60 (or whatever), assuming the hill is steep enough that engine braking is insufficient.
