MMI high 2g problem - audi a6 saloon 2007
patbor
Age
45
Hello everyone, I have a Audi a6 saloon 2006 with MMI problem. The problems is that the mmi keep stopping at every like 10-15 seconds for a second and then work again. This is happen on radio, CD or nav. The problem start maybe 6 months ago, but when I use the 3 button restart from the control panel this have been sort the problem until last week. The car have factory Bluetooth and may this be the problem but phone was working fine until last week too. Sometimes I have problem with phone connecting to the car but after delete the phone and pair again this sort the problem too. I have a cable and scan the car, clear all, and scan again. Sometimes the telephone was OK sometimes cannot be reach. I read a lot on the forums that maybe the problem is in the BT module but before start dismantle the car I decide to ask if anyone experience same problem or some one with more technical knowledge could identify and help me out.
I attach the full scan with VORB recognition and then few minutes later the other scan with no VORB and then another scan on Optical bus. I do not know which is exactly is the problem. What you think?
2 full scans attached and 1 optical scan:
Sunday,19,April,2015,21:17:39:26365
VCDS Version: sklad66.com Release 812.4
Data version: 20090214
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53
55 56 61 62 72 76 77
VIN: WAUZZZ4F07N042999 Mileage: 152170km/94554miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 F HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0030
Revision: --H01--- Serial number: 4217988
Coding: 0000001
Shop #: WSC 02325 785 00200
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020876
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601000500510
Coding: 0000019
Shop #: WSC 02323 785 00200
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350HV067710895
Coding: 0000002
Shop #: WSC 02335 785 00200
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 N
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial number: 00000030152028
Coding: 0001046
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
Part No: 4F2 910 113 A
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8170866
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U7400269
Coding: 0000001
Shop #: WSC 02324 785 00200
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0G4CVL
Coding: 0013381
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksдulenmodul H08 0230
Revision: 00H08000 Serial number: 90054062010262
Coding: 0102141
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
Component: KOMBIINSTR. M73 H18 0110
Revision: 00400000 Serial number: 5HS540U76
Coding: 2113443
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008067250039
Coding: ECFE73C41B3904
1 Fault Found
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 152173 km
Time Indication: 0
Date: 2015.04.19
Time: 20:55:16
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364H-067584364
Shop #: WSC 01179 210 93569
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: 9†
Coding: 0002682
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01017156150000
Coding: 0141819
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 43S00001 Serial number: 02407060325427
Coding: 0000003
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000270733
Coding: 0001103
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: 63†
Coding: 0002810
1 Fault Found
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 66
Mileage: 152173 km
Time Indication: 0
Date: 2015.04.19
Time: 20:54:16
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0000321
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394G$067671782
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000088485
Shop #: WSC 00656 210 60929
Part No: 4F0 915 105 D
Component: von VA0 0607311119
Coding: 344630393135313035442056413030363037333131313139
Shop #: WSC 00000 512 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0002090
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0002090
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330620500210
Coding: 0201106
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H13 0700
Revision: 00000000 Serial number: 00000007565025
Coding: 0010920
End ---------------------------------------------------------------------
Sunday,19,April,2015,20:49:30:26365
Control Module Part Number: 4F0 910 468 A
Component and/or Version: Gateway H11 0070
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
77-Telephone ERROR ERROR
47-Sound System OK OK
56-Radio OK OK
37-Navigation OK OK
0F-Digital Radio(DAB) OK OK
I took pictures of the current soft versions. I just want to mention that when I press Setup/return and the modules menu opened I can see all modules software, including the Handyvorb! Once I start open every one in detail for picture, the mmi refresh and the handyvorb disappear and become 0xFFFFFFFF, I made a video but could not upload due to size.
Sunday,19,April,2015,21:21:57:26365
Chassis Type: 4F0
Coding: 0011372
Coding: 0000001
Coding: 0020876
Coding: 0000019
Coding: 0000002
Coding: 0001046
Coding: 0013121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Coding: 0000001
Coding: 0013381
Coding: 0102141
Coding: 2113443
Coding: 0002682
Coding: 0141819
Coding: 0000003
Coding: 0001103
Coding: 0002810
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 66
Mileage: 152173 km
Time Indication: 0
Date: 2015.04.19
Time: 21:24:40
Revision: --H04---
Coding: 0000321
Coding: 0000016
Coding: 0000001
Coding: 0002090
Coding: 0002090
Coding: 0201106
Cannot be reached
SW: C6-HU 55.7.0 0835
HW: C6-HU 6350D2.0
FC SW: 05071AFC6AB320060
FC PS: 0060 FC HW: H02
It's not uncommon for the BT units to fail, also it could be a sign that water is getting into the car. The BT module is located under the carpet of the passenger side front seat, water can get into that area (From either the plenum chamber or the rubber bungs in the rear foot wells.
