05 A3 washer jets
NathanB
Hey guys, was wondering if anyone knows where the best place to get mist style washer jets for an 2005 A3 SE Sportback, or if they are able to be changed, cheers
Nathan
I don't think that mist type units would clean the headlight lens without wipers to assist.
You might find that with mist jets, it may not pass an MOT.
The jets are there to blow/wash muck off Xenons, so the minute you change a jet to a mist, you reduce the pressure.
Reactions: NathanB
Was thinking more for the windscreen, as done have headlight washer jets :)
Reactions: Jake 61
i think on the 8p2 models which yours is the passat ones need a bit of fettling, do a search as there are a few threads on it.
they fit the 8p3 fine as they aren't mounted on the bonnet like yours.
Reactions: NathanB
Passat ones are a direct fit; well they were on my 57 plate. They are mounted on the scuttle panel; not the bonnet ;)
They may require some trimming but we are talking 1-2mm at most
Order from your local VW dealer :)
Reactions: NathanB
43
673
NHN
709
20
Tay
