Hi,
I've been loosing all power to my drivers door for some time now. It started intermittently but it has not worked now for over a couple of months. I have no central locking (the other door and boot do lock/unlock with the key fob), I can operate the lock manually with the key, I have no electric windows or electric mirror on the drivers side. The speaker is working however.
After reading other posts I checked the cables leading to the door and they all appear to be intact. I also checked continuity between the connector block on the black gator and the door module within the door and they all seem to be fine. When connected the connector at the door module has power.
I suspect that the door module (P/N: 8P0 959 801 K) has failed. Has anyone ever seen this?
Is there anything else that could be causing this problem?
Here's my latest scan:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 52 55 56 77
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H8FN40R0
Coding: 0103000C180F0160
Shop #: WSC 06314 000 00000
VCID: 72EDE7E86D6198B168B-8027
1 Fault Found:
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 13
Reset counter: 255
Mileage: 89785 km
Time Indication: 0
Date: 2015.02.19
Time: 15:51:42
Freeze Frame:
RPM: 1522 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 35.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 1642801209260000681201E4901D00813D00
VCID: 75E7DCF4DC0F8F894D9-8020
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000394 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73E3E2EC127B91B963D-8026
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 15
Reset counter: 11
Mileage: 86784 km
Time Indication: 0
Date: 2014.11.24
Time: 09:00:46
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008928508
Coding: 118E0F27A01E1380EF00000A4F00000000084E0564060003002000000000
Shop #: WSC 06314 123 08192
VCID: 489965003B7D4261E6F-801D
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 64
Mileage: 86784 km
Time Indication: 0
Date: 2014.11.23
Time: 16:58:00
Freeze Frame:
OFF
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52330825709813
Coding: 000003
VCID: 418F7824D8477329211-8014
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8P0 907 376 HW: 8P0 907 376
Component: J250 Raddaempfung 0030
Revision: --H03--- Serial number: 190DPH 8148368
Coding: 0000132
VCID: 78F9D5C00B1DF2E156F-802D
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499F6004E877BB69F91-801C
Crash sensor for side airbag; driver side:
Serial number: 34928RB4000035986BF$
Crash sensor for side airbag; front passenger side:
Serial number: 35028RB400003FD216CQ
Crash sensor for side airbag; rear; driver side:
Serial number: 35128RB400003598735F
Crash sensor for side airbag; rear; passenger side:
Serial number: 35228RB400003FD1E6F0
Crash sensor for front airbag; driver side:
Serial number: 35547RB4000041D31B4H
Crash sensor for front airbag; front passenger side:
Serial number: 35647RB4000041D1D8AV
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 418F782418477329211-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 D HW: 8P0 920 982 D
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2248H006000365
Coding: 0101409
Shop #: WSC 01196 210 01865
VCID: 3A7D0FC8759120F160B-806F
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K089150493
Coding: E9AB1F064006020101
VCID: 35671CF45C8FCF898D9-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 88
Reset counter: 11
Mileage: 86784 km
Time Indication: 0
Date: 2014.11.23
Time: 16:58:31
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 4383722C025B613933D-8016
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H8FN40R0
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7MD204500
Coding: 0209757
Shop #: WSC 00250 211 85023
VCID: 346121F057F5D681BA7-8061
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 234 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5D3F888531907110B-807F
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 44817130075566010A7-8011
1 Fault Found:
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000029
VCID: 69DF808440B75B69D91-803C
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Modul links H03 S002
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Modul rechtsH03 S004
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209757
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005037578
Coding: 0011422
VCID: 46856B3831695411143-8013
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 255
Mileage: 89785 km
Time Indication: 0
Date: 2015.02.19
Time: 15:51:42
Freeze Frame:
RPM: 1522 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 35.0°C
Voltage: 14.224 V
Revision: 00H35001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 11
Mileage: 86784 km
Time Indication: 0
Date: 2014.11.24
Time: 09:00:46
Freeze Frame:
ON
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 64
Mileage: 86784 km
Time Indication: 0
Date: 2014.11.23
Time: 16:58:00
Freeze Frame:
OFF
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
Coding: 000003
Coding: 0000132
Coding: 0004042
Coding: 0101409
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 88
Reset counter: 11
Mileage: 86784 km
Time Indication: 0
Date: 2014.11.23
Time: 16:58:31
Coding: 0000005
Coding: 0209757
Cannot be reached
Revision: 00H15000
1 Fault Found:
Coding: 0000564
1 Fault Found:
Coding: 0000029
Coding: 0209757
Coding: 0011422
