S3 rear wheel bearing
goodbuzzman1
the other day I discovered that the bolt holding the bottom of my shock to the rear trailing arm was screwed in to practically nothing. No threads left in the Arm at all. So I sourced a replacement arm, removed the old one and started to transfer all the bits over. It was only then that I realised the my replacement arm has a wobbly bearing. (I know, I should have checked)The original one is perfect.
Do you think it is possible to get the good bearing out in one piece and slot it in to the new arm? Or will removing it just wreck the bearing
And how do you remove the hub?
I'm afraid you will have to destroy the bearing to get it out, but they are cheap enough, try carparts4less, gsf, or eurocarparts.
