New S3 ordered!
:hearteyes::grin::smirk:...
IMG 3633
Reactions: pburv, jungle650, Rob2k68 and 1 other person
Car really looks good. Loving the rims you have.
See my 3dr at same angle...
Reactions: pburv, batch and Jassyo06
Get them on mate - really pleased with mine.
Waiting for warmer weather and daylight - maybe Sunday? They look amazing!
Got a mate trying to carbon coat my tailpipes as well.
Reactions: pburv and Rob2k68
Didn't you have this done already? Didn't work out?
Or am I mixing you up with someone else who sent them off to a company who did them?
Kind of, had mine hydrodipped but my mate does actual carbon fibre work and wants to have a go!
Reactions: pburv, azibux1, Audi Bairn and 1 other person
Looking forward to the results! :D
Reactions: batch, pburv and Rob2k68
Your URLs have gone a bit messed up
Couldn't post the photos!
Because of the size issue? If so, if you're a facebook user, easy fix is to facebook message them to yourself as it compresses them :)
Carbon tailpipes coming and might buy some other carbon exterior bits. Don't want to go too crazy...
Oh yeah I'm waiting for your tailpipes you mentioned your friend is doing
Reactions: pburv and batch
Hmmmm, this is food for thought...
IMG 3969
IMG 3970
Thanks to @paradigital for the Photoshopping!
Reactions: pburv, Rob2k68, azibux1 and 1 other person
Where did you get the carbon interior trim from? Fancy that for mine when it comes.
This your own work batch?
I'm assuming you have put a carbon fibre sleeve over the existing tip?? :friends:
Not mine mate - my friend Paul. And yes they are the original trims that have been skinned.
Reactions: Rob2k68 and pburv
Ah ok cool, may have to get mine skinned then maybe.
Reactions: Rob2k68
Do they stick over the existing trim or replace it? How damaging to the wallet? :grimacing:
Reactions: Rob2k68
Should look the 'nuts' when finished ..:yes:
Reactions: batch and Rob2k68
Does anyone have a video of a DSG S3 or Golf 7R with JUST an aftermarket DP into OE exhaust system?
Reactions: pburv
Right, last Monday I had my Milltek Sportcat DP and GFB DV+, courtesy of @73pop fitted by my local VAG specialist MD AUTOBAHN. Anybody in the East Surrey/West Sussex area needing work done give Martin a bell. Superb service, he's just started out on his own after a career as a VW Master Tech and was very helpful and flexible.
I had to buy a new connector pipe to join to the OEM system, so this beast turned up - having never dealt with aftermarket exhausts on a turbo car before I was amazed at the size of the pipe!
IMG 4188
Quick comparison pic, OE downpipe/cat/link section on the RIGHT, note the awful restrictive bend at the turbo outlet end:
IMG 4238
Everything all fitted up perfectly, and ready to roll!
IMG 4240
IMG 4241
Managed to get out this morning with @sjbarneS3 for a good blast to check it all out, car feels much more eager, responsive and quicker and livelier from lower revs. Also an improved, throatier sound and louder farts on upshift but nothing too intrusive or chavvy sounding. After that, Mrs B drove the 30-miles or so to her parents (sedately!) and on the return journey got the dreaded CEL light come up! I'm popping out for a test drive shortly but can only assume it's due to the new exhaust as she says it's driving fine. So fingers crossed it's just that! If anyone has any definitive ideas to back me up feel free to drop them on here, unless I come back to say I've had to be recovered from the side of the road in an oily, smoky ball of fire!
Reactions: pburv, jungle650 and Rob2k68
I'd look at what has changed to cause the CEL... I think your sport cat is throwing lambda readings off which is causing the light. You need to scan the ECU with vcds to know for sure. If it is the sport cat that's the problem, you may need the ECU map adjusted.
Get it scanned to find out the exact reason for your CEL.
Sent from a mobile device, please forgive typos :)
Reactions: pburv
Hi Alex, hope you're well mate. I've got the MTM Cantronic box which can be reflashed but to be honest I think I'll be going for an O2 sensor spacer - either CTS, 42DD or even an eBay special?
Reactions: pburv
Hi mate, yeah all good here. The TTE420 is treating me well!
If you go for spacer, you'll need to get the sensor disabled in the ECU otherwise that CEL will never go out
Reactions: pburv
I hope not mate!
932
831
12
20
3K
