Check electrical connection to MAP sensor
Checked it just there mate seems all plugged in as it should be
Is your catch can full? That or your dip stick is just loose on the tube. My old stick i put a small washer on to keep it in.
Map sensor could be faulty. I had it a while back, bought another and it was fine after.
the new vag dipstick tubes are not as tight to the dipstick itself as they used to be.. so can rise a little..
your other fault codes indicate map sensor has expired
road test. bet you're gutted.
not
Nice to see it back up and running dude!
Thanks dude...yeah I'm glad it's back on the road after few weeks driving a kangoo van you can imagine my reaction to squirt in 3rd at 2 bar haha
Haha bet you did squirt at 2bar I miss mine badly. Can't thank bill enough for having my car lying around, he's got so many builds at the moment and to have my car sitting there must be annoying to waste space. If your reading mate, sorry!
Good time to upgrade to the larger bore manifold though
Yeah he's a busy man just now...I'm keen to see what the larger bore brings to the table..bill is putting some crazy cars on the road of late
I know! I've been following the TT stroker NOS build! That must be crazy!! Wouldn't mind a little shot of Nos! The larger bore could help my setup out, hoping it allows more flow even if it doesn't make more power, less boost would be nice.
Happy New Year mate.
I bet that fill up didn't last long!
careful ;-) you never know who might wrongly assume you were on a public road.
Yeh loads of those private Mexican roads round here too
I have read some of this but as a beginner I am not very good and still wont be making these stage 2/3 mods, but out of interest is your turbo moved from 2-5 to 4-7 but changing the cams or is your turbo now massive and therefore it just has a different range?
Bigger turbo doesn't mean lack of drivability... lag is a term I hate as it gets misused...
This is a plot of mine vs a std S3...
I don't have the boost plot to hand but in boost terms then yes you could call it 'laggy' but in real terms you are not missing out...
Don't get me wrong... if you are in 6th and you stick your foot down don't expect it to be like a diesel and just go... it won't... big turbo cars you do need to be in the right gear but once you are used to it they are perfectly drivable and once on song its another world
Manufacturers have been getting 500+ from 2.0 4 cylinders since the early 90s. Just not production cars.so does a hybrid do away with lag using an electric motor to simulate the exhaust gas? but they are not good enough yet? as the threads I have read here people are trying to get 300+ but your 3 cars are 500-600.
its pretty amazing from a 1.8 but I suppose the F1 1.6 are nearing 900bhp - so it must be possible for 4 hours driving or 15 minutes for a Honda.
Oh dear sorry - I thought the "hybrid turbos" being referenced in the modified S3 turbos were electric and gas power - I did wonder how it knew when to spool by electric as no-one talked about super capacitors, battery charging or ecu management - rather than different turbo components in the K04 casing, that makes much more sense.
so why not these - are they impossible to retrofit?
https://en.wikipedia.org/wiki/Hybrid_turbocharger
