Need some help guys!!
jay1601
kingsclere
leaving work today all good got nearly home and boost hose popped off put it back on took the car for a drive, was fine for about 2 mins of heavy boosting then nothing, brake lights are staying on and glow plug light flashing. Had a quick check of the wiring looks all ok. Done fault codes with is what I got
Motor for Intake manifold no signal p3102
Boost pressure solenoid (n75) p0245
Switch over valve for egr cooler open or short to ground p1495
Motor for intake manifold open or short to ground p3101
Relay for low output preheating of coolant (j359) open or short to ground p3004
Brake switch (F) implausible signal p0571
2.0TDI (BLB engine)
Any ideas guys need to use the car tomorrow for a meeting
sounds like brake switch to me, same symtoms i had, brake lights on, abs and coil plug light on, i think i had esp off aswell
Sorted the problem is was a blown 15A fuse next to the ECU
