Had a 360 mile round trip today and had a first for me where the car cut out completely which was a bit startling to say the least.
Firstly the story.
So, after about 50 mins of driving I got an error on the DIS of "Electric Parking Brake Malfunction" and the car (I think) went into limp mode i.e. I could only slow down, had no power etc and as soon as the car came to a complete stop power was cut to everything - not very helpful as I had pulled into a service station.
I turned killed the ignition, went for a leak, came back and when I turned it on everything seemed to be ok.
About 30 minutes later it did the same thing and I coasted across to the hard shoulder, came to a halt, lost all power killed ignition and after a couple of minutes fired the ignition again and everything seemed ok.
That was this morning on the way up and I got to where I was going (had to carry on as a very important meeting). On the way home (appx 180 miles) I had absolutely no problem at all.
I've done a scan and the details are below - there are several faults that all seem to be a ripple effect. I can see that the Electric Parking Brake is showing an intermittent fault and looks to be the first one triggered at 07:01:28. Would that cause a ripple effect through the gateway?
Also worried with the fault showing at 07:31:01 which shows as 00562 - Sensor for Oil Level/Temperature (G266) - sounds serious, is it??
Any help really appreciated.
Firstly the story.
