Catch can
RB S3
Hi guys. Can someone recommend the best catch can to use? Any links to ebay items?
Better to be baffled...
If you're venting back to TIP make sure it's baffled. If you're venting to atmos use whatever you want.
It will make life easier if it has 19mm inlet and outlets
How do you vent to atmosphere?
Instead of the catch can going to the tip you just let it vent into the atmosphere. Make sure you block off the TIP so no unmetered air sneaks past the maf. People sometimes out a little filter on their catch can, or run a hose under the underbay as you can get a bit of an oily smell
The vast majority of catch cans that I've seen aren't baffled, I even went for a slightly more expensive one to ensure it was baffled... it wasn't! Vent to atmosphere and all is well. I had a little filter on mine, but soon changed to the pipe running down by the gearbox.
653
624
489
21
