ABS module not coding
bskmiki
Hi,
I have an Audi A4, 1.8T, year 2002
I'm trying to recode the abs module using the rosstech video tutorial
That's how I try :
1) Switch ignition On
2) Connect the VCDS to my car
3) Go to ABS Brakes
4) Then I go to this link http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Brake_Electronics_(Bosch_5.7)
5) There I select my type car , than [03] - brake electronics & than Bosch 5.7
6) There is nummbers I need , if I understand it correctly I need Login 09575 & Coding 04275. Correct ?
7) Than back in VCDS I select Login and enter 09575
8) Than I select Coding and enter 04275
And right now my problems begin :(
VCDS reconnect's to ABS , than it shows that soft coding is 00000 & wsc 00000
And nothing happens.
Can anybody explain what I doing wrong , why I can't reprogram ABS ?
I posted a vido on youtube with the problem.
I've tried with diferent VAG-COM cables. Same thing every time.
Does anyone know what to do?
Is this a genuine vcds cable, if so, email ross-tech & ask them to confirm the procedure, it does work as I've done this myself many times, but the car coding has to be exact to the cars pr codes, braking systems installed.
689
605
965
