Boost leak?
Y111_PJL
Newcastle, United Kingdom
Has anyone got any hints or tips on trying to track down a boost leak? Tried the soapy water test around the pipes and fittings I can see, and no bubbles seen.
Any where on the car I should be looking at specifically? I know what if the intercooler pipes is quite a common problem?
Failing this... Anyone suggest a garage in the north east that does smoke testing?
Cheers.
Did you pressurise the system when you soapy watered the joints? You've got to have a bit of pressure in the system to see a leak.
Could also be the vac system leaking or even a split dv
Dump valve is sound. Took it out, checked it. Even ran a different one for a day and no difference in noise.
Put the soapy water on, switched the car on and give it a few revs (neighbours weren't happy) but I never seen anything.
The is a pipe at the left rear of the engine (like a PCV pipe at the rear) which has oil all over it?
Check the pipes coming from the turbo ... get someone else to rev it, and try and have a look at the joints of all turbo pipes. Try and get underneath the car / or just get it on a ramp. You'll find it, it's just a matter of when.
Could be the pipe that's covered in oil.
I'd still take it to a smoke tester, saves so much time looking for a leak.
Pipe in question...
19
13
4K
963
754
9
S.
