Inlet Manifold Flap 2007 2.0tdi 170 special edition part number?
soldier4313
A4 Avant B9 2.0 Tdi
41
Germany
i have a 2007 a4 avant b7 special edition tdi with the 170bp engine and I think my inlet manifold flap under the egr valve has gone as there is oil around it and a small rubber seal is pretuding out. My plan is to clean the egr valve this weekend and I would like to get a second hand IMF and change it at the same time. Does anyone know the part number?
I have the same engine, mine was A2C53099815 when I had to replace it. It is common for them to have build up around them, I would give it a good clean first before replacing it. Whilst you're there take apart the manifold and EGR and clean that as well. This made a considerable difference to the drive after I done it.
A good sign that it has failed is that the car judders when you turn it off. It is, after all, an anti-judder valve.
