Leaning towards blocked rad now, fault finding is sh*t at the best of times but having to remove the front of your car to carry out maintenance.....go figure!
Next on the list mate. I know I should have got that test done sooner.I'm surprised you haven't had a HG sniff test done? Cheap & easy way to establish if you have HG failure.
Thanks vr6girdy!Why are you wasting your money on things it's not I told you right from the start it was your head gasket .. You could of had it all fixed by now chances are now you've cracked your head and will need a new one now
No dude. Try and keep an open mind, it's too easy to focus on something obvious like head gasket.So your putting back on a part that you had on and the problem was still there with this part fitted ..so why you putting it back on ?????
I recently fitted a genuine stat. There are wee plastic clips, which I may add I never noticed were there, that were to keep the orientation correct or something, but I now believe is old tech as orientation doesn't matter anymore I believe? I stand to be corrected though.Ordered a new genuine thermostat from Darkside and even though the temp reaches 90 the bottom hose remains cold. I'm only driving 10 miles to work so a hard drive tomorrow will properly check it.
Just a question, does it matter how the thermostat is orientated when fitted?
I haven't been tight mate. Radiator,water pump, cambelt, expansion tank etc.Can't believe you've still not fixed this .. Stop been tight and spend some money ..
Can't see how a compression test will help?Have you had a compression test done yet ??
You got me thinking dude! Not just a flexible hose but the metal pipe linking the heater matrix outlet to the block via the oil cooler. Thanks.Wonder if you've got a water pipe that's sucking in on its self blocking the water flow
Can you remember if his thermostat was opening? You're probably right mate but if it is getting that hot why won't it open and circulate like it does with the thermostat removed?My mate had exactly this on his 2003 PD130 A6.
Was fine if he drove gently. Give it beans and it would boil over and spew the coolant everywhere.
Went thru everything you've done, until i eventually convinced him to change the head gasket. Did that and it sorted it.
Probably worth changing the timing belt and water pump while its apart too.
But my stat will not open even if it is boiling. Basically with a stat fitted the bottom rad hose is now cold whatever happens temp wise.Yeh his stat was opening fine, infact it was potentially the stat that kicked off a whole sequence of parts. The original stat was opening too early, and the car was never getting to 90c. One day he was driving it particularly hard and it boiled over. I suggested the stat might be stuck a tiny bit open, meaning it would run cool normally and then boiled over because that stat didnt open fully. He replaced the stat with new and that made it come up to 90c nice and quickly, but it would then boil over almost every time he took it out. Initially he blamed the stat like you, then went on to blaming the radiator and water pump which he paid to have replaced. Infact it was simply that with the engine now running at 90c, there was much less headroom for the temperature to rise when it was overheating.
IMO, The missing stat is just masking the issue, by giving more headroom before the pressure and temperature gets too high.
Everything is worth considering mate I think. It looks a pig to get to though.I'm sure the CTS housing cracking is common. I've heard of it on the 1.8t anyway.
Fairly difficult. But as Gordy says, it's the headgasket.Everything is worth considering mate I think. It looks a pig to get to though.
How difficult is it to remove the housing?
It will only be warped if it's had some serious heat. 110-115 will not be enough to warp it.If it is the head gasket your cylinder head will be well warped now but after a skim and all out back together you will have more power
Not necessarily.Still wants a skim to be right
