Stereo...
.-Samuel-.
Audi A3 1.4 TFSi 09 plate.
I bought a Xtrons stereo off ebay,normal one with say nav built in. Ive fitted it and everythings fine. I want rear speakers and I want to add the boot sub for bass.
How do I go about wiring/installing this?
What do I need?
Is there any tutorials I can follow?
Thanks in advance.
Sam
If you could answer my questions from the first post then that would be much appriciated
Well for a start off I'm not gonna help you upgrade rear speakers leaving front stock. It will ruin the stage and there really truly is no benefit to doing it
You need sub, box for it, amp and amp wiring kit. There is a pdf floating around how to get wiring through the firewall which you may find useful
You will also need one 5m run of rca wires to take signal from your head unit into the amp assuming the head unit has rca out?
So would it make a difference changing the fronts to better ones to match the rears?
Ok yeah ive got all of that. Ill have a look for the pdf for the wiring,seen the wiring bypass harness on ebay,would one of them work?
608
762
481
770
NHN
387
