There should be a u clip to hold the pipe on, it slots into the plastic part of the slave cylinder then the pipe clicks into place, it's more than likely the clip has corroded away and the hydraulic pressure has blown the pipe off, not sure if you can get the clip separate,everytime I've replaced a slave they have come new with the slave.
Thanks for the help, car went to the garage in the end they put it back on and got the pressure back. Needs to go back tomorrow so they can put a new connector on.
