Audi A7 2012 /245
mgluba
49
Cambridgeshire
Hi,
Anybody knows how to fix the following fault codes ?
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 000000000000000000000000000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316F639F60AB8896243-8064
2 Faults Found:
12585984 - Control module not coded
U1013 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Mileage: 75809 km
Date: 2015.09.24
Time: 09:40:27
12589824 - Data Set Implausible
B2012 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 75809 km
Date: 2015.09.24
Time: 09:40:27
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 326D6C9365ADB38E5D9-8067
2 Faults Found:
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 75809 km
Date: 2015.09.24
Time: 09:40:27
B2012 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 75809 km
Date: 2015.09.24
Time: 09:40:27
Regards
Have you retrofitted a system to the car?
I ask as it says control module not coded, if its under warranty, take it in, check module coding available, then assess what it can be coded for, yeah I can see now its pretensioners, never knew they separated them on a module basis, usually direct to the airbag controller, oh well everydays a school day.
Reactions: bearthebruce
Need to use vcds and go into module and as nhn says see what coding is showing if any!
Actual looking at your post there is no code in the module!do you have any previous scans before fault that should show original code?
Hi,
Yes I can see that - but I'm the second owner so I havn't got oryginal scaning
It looks like something new has been added but there is no coding for it ?
