- Joined
- Aug 20, 2015
- Messages
- 17
- Reaction score
- 5
- Points
- 3
Hi,
Trying to figure out my faults... Possible DV issue.
So I've taken the diverter valve off and done the test where you push the valve up, and put your thumb on the top hole.
When I release the valve at the bottom, it immediately closes a bit over halfway then holds vacuum indefinately. Is this a faulty valve or not?
Everything I've read about this test just sais a working valve will hold vacuum, a faulty one will lose it. I'm not sure where mine fits into this, since it goes over halfway then holds it, and I cant find anything relevant on my searches.
Cheers guys,
Pat
(*edit - When closed the valve seems fine, I cant get any air through. Problem is when letting off throttle, can hear what sounds like flutter/turbo spooling down. Diagnostic cable is on its way, they've sent me the wrong one twice. Mainly want to know if my DV needs replacing to help isolate other faults when my cable arrives.)
Cheers guys,
Pat
