Coolant Flange replacement
TheAngryDog
Guys, I've finally got all the parts I think I need to replace the broken coolant flange on my 1.8t. I've stripped down the engine as I am replacing the thermostat housing as that is also broken, and replacing the hoses as they're brittle, soft or oil contaminated.
I am having trouble getting the the flange however, and the only way I can see to get to it is to remove a part at the back of the head, seen below.
Any ideas how to get this off please?
Thanks.
Undo the 2 clips on the pcv type valve and pull it off then there's 2 10 mm bolts hold the egr on.your arrows are pointing to breather system I'm not sure exactly what you want to take off??
