yeah it was already broken, I wouldnt mind changing the section of loom if its not too hard and possible? Yeah all wiring seems good, but I will have to double check it, might move the bits and pieces out the car and see if theres anything not quite right.
Coolant level hasn't dropped, and oil seems fine also, i did buy the car knowing this issue, and done roughly 200 miles in it since, it drives as you would expect, and only misses when cold, also noticed the temperature needle doesn't really move, sometimes it does, other times its dead, do you think this would be down to the dash pod? or possibly a sensor? VCDS has no errors on a temp or coolant sensor..
all the bits are starting to annoy me now, as it was meant to just be a project to sort over a few weeks, get it prepped and have a nice reliable winter runner...
I've brought a full set of bosch super 4's and a new oil filter to have done on the weekend as well, but now I'm more than likely going to leave doing that until I can get it running right, also think its in my best interests to clean the oil up pipe as I doubts its ever been done, picked up 20LT of triple qx c3 5w30 oil for £48 at eurocarparts as well which will see her for 4 services hopefully
