Noticed on the freeway when pushing the car a little there was a little drop in power. I thought hmmm that's strange - so i decided to take it out and do a couple of runs.
1st gear felt like it pulled heaps more than it did before i had any errors.
2-3-4th gear power would build then drop, and come back on, and drop etc from around 3.5k (not very rapidly)
scan reveals
5 Faults Found:
17956 - Boost Pressure Regulation Valve (N75) P1548 - 35-10 - Open Circuit - Intermittent
17743 - Engine Torque Monitor 2 P1335 - 35-10 - Control Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235) P1453 - 35-00 - Open or Short to Plus
16486 - Mass Air Flow Sensor (G70) P0102 - 35-10 - Signal too Low - Intermittent
Going re-check wiring and plugs as stuff may not have been plugged it properly after installing a catch can. Other than that does it look like i may need to replace some (more) electrical bits?
scan reveals
5 Faults Found:
