WHERE WOULD I GET THIS AUDI S3 ?
Audis32015
Hi Guys
Does anybody know how I could fix this side panel on my s3 ?
You need to remove the panel, there are three rivets, (or sometimes Torx head screws), under the door rubber, and either replace them, have them wrapped, or spray them.
That's quite a common problem and there are lots of solutions out there.
My one's are the same but worse, so they will be getting painted when I have time.
As above. Open drivers door, use old plastic card to force the rubber to the side, drill out the rivets take the panels off, sand & paint them or wrap them. Put back on with a £5 rivet gun. Sorted.
Yeah as above, common issue, I would upgrade to the newer glss black trims tbh, but wraps a cheaper option.
They are B pillar trims . My were screwed on at the bottom and the top fixing just hooks on. Think I paid £27 + vat each at the Audi parts counter. Wrapping or painting is a cheap solution though.
On my sportback I sanded them down and vinyl wrapped them matt black. So far so good. Only time will tell but for now they look crack on.
G
745
_G_
G
783
13
