Hi Folks
Newbie here,
I'm trying to confirm If my Balancer Shaft/Oil Pump has been replaced.
I have a B7 A4 Avant 2008 2.0TDI 170 engine code BRD which I've had about 6 months, I've recently been reading on this forum about the balance shaft Issue with these engines (which I wasn't aware of) which was a bit worrying. I then remembered there was major work carried out on my car by the previous owner about 2 years ago @ 77,000 miles which I have the Invoice for.
Apparently the oil warning light had come on and car was rescued to local Indie garage where It was repaired to the tune of over £2,500. Main parts replaced were a Housing @ £950, Oil sump @ £129 and new Turbo @ £ 675.
Not being that mechanically minded, my question is as the oil pump/balancer shaft hasn't been listed as a replaced part, is this due to the fact that It is contained In the Housing? Or is it a separate component altogether?
If it still needs done how much at risk is my car to this problem, as I've read on here the later B7's aren't quite as vulnerable.
Many Thanks In advance
Newbie here,
