I wasn't very happy with the JB1 after I had fitted it to my S1, so I sold it.
My thoughts are documented here.
Can you let us know more info mate? That link doesn't work for me?
I got from US, order it from burgertuning.comWhere do you get these from ?
Well, from what I understood JB is also connected to the fuel sensor that DTUK does not.
And also you have the possiblity to tune it your self a bit. Connect the "box" to your computer and change some settings.
Should work with different fuel types/quality and aftermarket downpipe, intake (it think).
http://burgertuning.com/jb_vw_stage_1_tuner.html
And also possible to upgrade firmware by yourself.
http://www.n54tech.com/forums/showthread.php?t=34711
So, I'm might actually go for that. Or wait for the coming JB4 (no date yet)
It got 4 sensors boost pressure, fuel rail pressure , cams timing and other one on the manifold for fuel or air intake temp. Also this jb1 is beta version which can be upgrade to jb4 once its launch, the single wiring connect thru jb1 box thru obd2 plug.Well, from what I understood JB is also connected to the fuel sensor that DTUK does not.
Ok, thanks for that information. So it should be ok to buy the JB1.It got 4 sensors boost pressure, fuel rail pressure , cams timing and other one on the manifold for fuel or air intake temp. Also this jb1 is beta version which can be upgrade to jb4 once its launch, the single wiring connect thru jb1 box thru obd2 plug.
I know the guys on baby Bmw rate these highly for use on the m135Ok, thanks for that information. So it should be ok to buy the JB1.
