storm.rift
Hey guys,
Long long time reader, first time posting.
Will be dropping in a forged engine soon but have some questions i simply cant find answers for and/or be easier to have them in one place
I currently have my pre facelift A3 Q running basically S3 turbo conversion inc FMIC. Mapped by Rtech - no graph but after a phone call they suggest its about 280 ish.
My goal for BHP is 450/500
1)The forged APY i bought has Wiesco forged pistons and ARP rods - The engine builders have advised the head is running solid lifters and the valves seemed like they were double sprung - Is there any way to confirm or deny what is or isnt fitted to the head valve spring wise without stripping it? As i have no proof of what is exactly in the head just hear say and i dont want a tune based on what is there and break something or lose out by not having it tuned for what might be in there.
2)I have my self a Audi TT ecu for the wideband EGT conversion - i have a complete engine loom from the S3 it was in as i broke it for parts, so will just swap the engine loom when i get round to swapping the engine. When making the move from Narrow band to wideband, i also have the clocks and matching ECU, from what i read it is possible i cant use the S3 clocks depending on 2 or 3 plugs behind the clocks in my A3. Not checked yet to confirm and unsure as seems i can only find limit info on this. - most being why dont you just have the S3.
3)Hopefully i can use the clocks - ECU currently has a Badger5 map on it for somewhere around 330hp. Can anyone foresee potential issues running this ecu + clocks without mapping - i am thinking it is an issue and will need to be on a flat bed to tuners once all is in. Ideally dont want to immo defeat the ecu.
I am struggling on turbo choice -
GT28.. wont make that power
GT30.. possibly - but still unsure as full boost is about 4100rpm? and i have a 1.8 bottom end not stroker.
TD06 - Quite possible to make the power again not sure on how this will perform on a 1.8 bottom end.
Unsure on turbos potentials/downfalls, but asking so i do it right first time.
I know a lot depends on the head possibly having at least valve springs, also its not going to be ideal having a small port head. But my intentions are not to rev the nuts off it but maybe if the hardware is there to allow to raise the rev limit will help. Suggestions, thoughts?
4) I'm assuming as i haven't found anything to contradict this in my search - AGU head uses the same size valves as a small port, it is the runners in/out that are larger - hoping this is the case as if it turns out my head does have these and i can reuse these valves i can switch to a large port head.
Parts i have collected so far for the conversion:
Deka 630cc injectors (i know ill be needing bigger after researching maybe)
AH Fabs FMIC
Engine as above.
TVR AP Racing Calipers - Badger5 brackets.
Apexi AVC-R Boost controller
Possibly Emerald K6 stand alone - undecided if ill use this yet..
Manifold if i'm correct tubular will increase spool time, but gain top end and likes of the K04 JBS style manifold will help spool sooner but loose top end.
Long post sorry - but hoping you guys can help me be a little more decisive on turbo/manifold etc with some real experience. Keeping my options open on ecus turbos etc hence the confusion on TT ecu,emerald etc
AH Fabs FMIC
Engine as above.
