Safety first!
Reactions: Tyrer and Sonny Singh
Washed it for the first time in a couple of weeks, and fitted an even smaller number plate than the small one I had already fitted...
I really like the front one but I can't make my mind up about the rear. The one fitted is 16" but I don't know wether to leave it, go back to the original 22 1/2" or fit one the same as the front (13")??
Reactions: Sean_
Love those tips John! They 3.5”?
Reactions: J0N
Thanks. They're 80mm (about 3 1/8"), they're from the eBay shop in Cyprus that a few of us ordered from earlier in the year. I'm really happy with them and they always come up like new.
One of the first things I decided I was going to change on my new A4 Avant was to add a glovebox CD changer and Aux In / Bluetooth connectivity.
The car has RNS-E fitted.
20170823 1218052
As there is no glovebox CD changer the space at the top of this box will not hold a CD changer...
20170919 1338152
A quick search on ebay to find a glovebox or liner, CD changer and connecting cable...
On my old A4 I had used a XCarLink Bluetooth unit and found it worked pretty well so ordered one compatible with RNS-E, it came with ipod cable but I have no use for that, only Aux In, USB and Bluetooth.
20170919 153547
In the pic above you can see the new box fitted, CD changer installed and the cable for the Bluetooth unit fed through one of the pop-out squares on the back of the glovebox.
This is the connecting cable needed to hook up the Changer, the Bluetooth unit hooks up to this too so just follow the guide supplied with the cable and everything will work fine. Best if you have the special tools for removing pins from the Audi connectors as they are a pain to do. I just about managed with a metal hair clip. Get the tools and save youself a half hour of swearing at cables.
20170905 173210
Another small job was to change the lock over from my old glove box to the new one, in the two pics below you can see the lock screw to remove and where to insert a flat head screwdriver to pop the lock out carefully...
20170919 1346262
20170919 135637
This is it all up and running. The cable you see is for the bluetooth button and mic for handsfree, I still have to figure a good route to get it into the cabin discreetly, a job for the next few days.
20170920 0935432
A quick idea of how it works, for example if you have the Radio on and you switch to CD and select Changer (no coding needed for new changer) the first time it will play from CD chager, switch to Radio and back again to CD this time the audio is from the Bluetooth unit.
I'm sure there are easier ways to get Aux-In and Bluetooth but I chose this as I had used it before
Reactions: Sean_, zgss20v and J0N
Thought I’d have a play with my old standard headlights. So cracked them open went for projectors with square halo to replace sidelight and hydro-dipped the chrome blade inside the light.
Not to everyone’s taste I know but I like to be different lol
Reactions: dubcool.pc, Dani_B19, Charlie Farley and 5 others
Looks good and im a fan of the yellow graphics onky thing i would say is need to lose the amber lense in the headlight
Sent from my SM-A300FU using Tapatalk
Reactions: JMGR33N
I was going to do that but the clear lenss are crazy money for what they actually are. The whole conversion only cost me £30 and some time lol
Yea i know ive got a set of clear lense that i was trying to sell as never done mine and would rather upgrade to xenon when ive got the funds that a cracking mod for £30
Reactions: JMGR33N
I just bashed the amber lense out with a screwdriver and put some chrome bulbs in that flash amber
Reactions: LawrenceH, JMGR33N, Sean_ and 1 other person
Clocked over 175k today old girls still pulling well tho. On another note had an insurance quote for a new a6 and adrian flux want £1186 compared to £300 i pay for my b7. What a joke insurance is
I was with Flux on my Discovery so kept it when I swapped for the A4. Renewal came in at £570, I paid £370 with quote me happy in the end. In my experience they’re good for anything modified, anything standard they’re rubbish.
Reactions: V6_Man
20171002 141245
Finaly found some time to update the music...
Can anyone take a picture of the n/s/f fog light. Ive found the insert behind the lamp loose and its annoying me now i know.
There you go....what are you looking for??
Reactions: MartinHudson6
Looks like mines come loose/off then. Just had work done at audi and theyve had bumper off. Thanks for picture
Reactions: J0N
Replaced my n249 valve as it wasn’t working and causing the eml to come on.
Also did the clutch master cylinder on the TT, second time this year
Engine went back in today after a full rebuild and being out for over a year!
Also tried to do the front control arms, apart from the upper ping bolt sheared off due to being seized, and is impossible to get out -_- any recommendations or where to get a replacement upright? Or how to get the ******* out?
Reactions: Dan-1981
When I did my springs I had to cut through the control arms to remove the bearing housing, I then had plenty of room to thrash the pinch bolt with a pin punch.....
I have heated it up and thrashed it with a punch and a sledge hammer, it’s super seized!
Maybe I will try to heat it some more....
1. Booked a remap at Keith Edwards Motorsport
2. fit new centre caps
3. Ordered Goodridge Brake Hoses
4. Ordered paddle shift extensions
Changed rear wiper arm on my avant for the Q5 version.
Before:-
20170908 173814 4780x2689
After:-
20170908 180250 3984x2241
Fitted it at the same angle as the old one but think it should be adjusted a bit more so its horizontal.
Reactions: Jack Kelly
Got some new wheels fitted today, absolutely love them.
Zito 935 19 inch 5x112
8.5j et 30
What you guys think??
20171014 175823
20171014 175810
20171014 095816
Reactions: A4hybrid, Charlie Farley, J0N and 4 others
looks excellent chap, are you using spacers aswell or just rims with the ET35, very nice indeedy.
Been meaning to do this for ages, did you buy the covers new??
Yes mate. Had to be ordered in but at £48 approx much cheaper than ebay and breakers. Thats without getting any trade discount aswell.
Reactions: J0N
Have you got part numbers??
345mm upgrade
IMG 0288
Reactions: GDCAUDIA4B7, zgss20v, V6_Man and 2 others
4gb limit isn't it? And 32gb on the MK2 rnse..
Sent from my Nexus 7 using Tapatalk
Reactions: carlcall
