So the wheel wobble I have is still there and it's driving me insane now!
Other than balancing I've narrowed it to the wheels themselves.
Does anyone know of somewhere not too far from West Yorkshire (but I am prepared to travel) that has the dog's danglies in terms of wheel balancing machines? I'm not so sure how often the local independent tyre centre has theirs calibrated and its important to me because I may spend on new wheels on the back of the outcome.
I'd be prepared to travel up to 1 hour to get it done and done properly.
Secondly, if the balancing can't fix the problem then it can only be the wheels. I've borrowed a set of genuine A3 Rotor wheels from a friend and that cured the wobble.
My wheels aren't buckled so it leads me to believe that my alloys being the wrong spigot size and needing spigot rings is causing the issue.
My question is if I have no choice to change the wheels do I go for a set of used genuine A3 wheels (because the spigot size will be correct and won't need spigot rings) or do I go for a set of TD Pro Race 1.2 which the company have said they can make for me in the correct spigot size, so wouldn't need spigot rings either.
What is everyone's experience and opinion of the TD Pro Race 1.2?
Reason I ask is for the price of a used set of A3 wheels I can buy a brand new set of TD's...
Thank you,
Sayam
Thank you,
Sayam
