A3 2.0 tdi 145000 miles just had cam belt kit and water pump now the car seems to be rocking when just ticking over and sounds a bit lumpy drives lovely otherwise any ideas??
timing wants looking at, if who ever has done the belt has done it without the proper locking pins, defo the timing will be out. they miss and shake bad when its out and very easily done. you might notice more smoke out the back than before as well.
Thanks for the reply he took it to the garage where work was carried out and was told its nothing to do with timing belt work and what do u expect for the mileage??
Hi, I'm Having this issue with my 54 plate a3 8p mine was doing this before I had the cam belt and water pump done also the EMl Light is on due to a faulty cam shaft position sensor, so I assume it does have something to do with the timing.
