Martintl
- Joined
- Feb 4, 2016
- Messages
- 53
- Reaction score
- 8
- Points
- 8
- Age
- 30
Yeah exactly! Im running mine under the sillsYeah i mean not like anything is gonna hit them while driving, plus its quicker and easier the way i see it.
I have yeah mate, all pretty simple. Buy a 3 amp fuse tap, tap into the fuel pump fuse with the pink ignition wire. Red goes to positive terminal, black to the negative. Run the wires through the car to the boot. Red and black to the compressor and connect your connectors. Also you need a 30 amp fuse which youll get in the kit hooked upto the positive cable right next to the batterySweet, have you done the wiring side of it yet?
i have a brodit clip on the triangle piece of plastic next to gear stick with my controller on it
Thats exactly what i thoughtWouldn't fancy putting it on the passenger side dunno who would end up messing around with it looks good though!
19" and yeah, uprated shocks with cur bracket and slam series below bagsNice 18 or 19? Yours looks a tiny bit lower. Did you change ur rear shocks? Are u running Sleeve bags vs Bellow bags?
Clean what's the spec on those wheels? I'm still using OEM shocks, plan to upgrade when they go. Airlift shocks apparently don't have much lift, I hear good things about koni sports. Today I trimmed the arches and removed the bump stop, I'm tucking (19'' et35 225 tyres) front and back a little anyway. Front from the highest arch lining to ground is 55cm and rear is 56.View attachment 85249 View attachment 85250
this is mine on 18s, i still am using my old shocks of fk coilovers, did you guys use airlift shocks? or recommend any other brand? just heard airlift go really low so when i want to tuck in the future by smaller J wheels, il be able to go much lower, as thats the max on fk shocks :/
What arch trimming did you do? I need to mine very soon! Not a clue where to start hahahaClean what's the spec on those wheels? I'm still using OEM shocks, plan to upgrade when they go. Airlift shocks apparently don't have much lift, I hear good things about koni sports. Today I trimmed the arches and removed the bump stop, I'm tucking (19'' et35 225 tyres) front and back a little anyway. Front from the highest arch lining to ground is 55cm and rear is 56. View attachment 85316 View attachment 85317
Yes there is a bump stop and only arch work that needs doing is a bolt taking out of each arch liner i think..Im running standard shocks, is there a bump stop on them? Ive not done any arch trimming but then again i haven't put on my other wheels yet
Im now running dual compressors, look abit tatty atm as i need to redo the carpet and need to redo the hardlines but you get the ideaAny updates with the builds lads?
looks damn clean!Im now running dual compressors, look abit tatty atm as i need to redo the carpet and need to redo the hardlines but you get the idea
