So I believe i will need to fuse taps cables.. and they have 2 slots each one.. any idea apart of the original fuse what have to be the amp of the extra fuse if wanting to hardwire a Blackvue camera? I understand one cable goes to ground another to a live fuse even when car is off and another to the cigarrette lighter fuse per example.. is that correct? Sorry a bit confused.. would appreciate if someone could clarify
Many thanks
That's very helpful Rob thanks for accurate answer!I used a 5 amp fuse in each of the fuse taps.
Black is earth
Yellow is permanent live
Red is switched accessory live (cigarette lighter)
As per these instructions :-
http://www.dashwitness.com/wp-content/uploads/2014/11/Power-Magic-Pro-Manual.pdf?bb8989
These are the locations I used for the fuse taps :-
http://www.audi-sport.net/xf/thread...d-a-blackvue-dr650gw-2ch.248726/#post-2680657
Top one 25A is perm live so yellow wire and bottom one 20A is switched ACC so red wire.
Will it be enough just by adding 5 amp fuse to each of the taps? Did you found any problem at all? Also how do you have the switches on the box itself the 1-5 switches.. Sorry for many questions I just don't want to mess it upI used a 5 amp fuse in each of the fuse taps.
Black is earth
Thanks for that
Brilliant Rob!! Thanks again for that!!5 amp fuses are fine.
Only problem was the earth I found the bolt on the side that others have used unreliable so drilled a hole and used a self tapper as per the BlackVue installation thread.
Here is how mine is setup, with only switch 4 on this keeps the camera live for 24hrs after removing keys or if battery voltage hits 11.8V whichever happens first. If you only want it live for 12hrs then flick switch 5 on instead of switch 4. These are probably the most common settings but all are shown in the power magic pro pdf that I linked too :-
