Not wanting this one not spotted
emmamac
Hi everyone.
I know I know I know wrong place to post but I've already posted in the A5 section with no reply.
I'm an owner of a 2012 a5 cabriolet and want to get the voice control to work as most of you know Audi deliberately turn this feature off.
My question on other post is,
Can this be done if so does anyone live close to wrexham or can give me instructions on how to do it and I'll pass this information on to someone with VAG.
And satnav also needs updated.
HELPPPPPPP.
Thanks in Advance.
Emma.
You are aware its a bank holiday and people do other stuff than spend the day on here?
Give it a day or two.
Reactions: Nilz
Try posting in the A5 section. You will probably need to say which MMI version you have. Sat nav update is dependent on wether it's on SD card or HDD.
Can't help you with voice control unless it's in the hidden menu? The sat nav update is quite pricey, the guys on the A6 forum are saying about £400 for the SD card and then the dealer has to update as it is configured to the car.
Maybe try the A4 B8 section?
Good luck.
Just found this,
The Audi A5 Cabriolet and S5 Cabriolet come with everything needed to support the voice recognition system (a.k.a. “voice command” or “voice control”) present in other Audis, but it’s disabled by default. I guess Audi thinks it won’t work well enough with the top down or something. That doesn’t seem like a good reason to leave it disabled with the top is up, but who am I to say? In any case, it is possible to enable it, and in my testing it works just fine (in fact, it works better than the older generation of voice recognition in our 2007 Audi A6). I did this on my 2011 S5 — it should work on any A5/S5 Cab with the same MMI system, but I make no guarantees. Obviously, any change you do like this is done at your own risk.
This information is on most of the forums, but I thought it was tricky to wade through all of the threads and find the simple, reliable way to do it (many of the posts explain an unnecessarily convoluted method involving enabling the hidden menu, changing languages, leaving the car to sit overnight, etc. — you don’t need to do any of that). If you have access to the VAG-COM VCDS software, this is very easy to do. If you don’t have access to VAG-COM, I highly recommend getting it either by buying your own cable or finding someone who does. It’s useful for many, many things.
Here’s what you do:
  1. Connect the computer to the car and fire up the VAG-COM software.
  2. Select the Electronics 2 tab, then Module 5F.
  3. Bring up the Long Coding Helper and change byte 16 from “01” to “00” (the last 5 digits of the entire code should be “10000” instead of “10100” when you’re done).
  4. Click “Do It!”
  5. Exit the software.
  6. Reboot the MMI by simultaneously pressing “Setup” the knob center “joystick” button and the upper right button.
That’s it. Once the MMI is done rebooting, the voice recognition button on the steering wheel should work. Again, do this at your own risk, and be careful poking around in VAG-COM — it is possible to mess things up. Don’t blame me ;)
9
718
bainsyboy
B
10
736
