Hi All, I have an idea of what the problem/s is/are, I'd just like to get some of your thoughts and opinions to be sure so i'll list the symptoms and see what you guys think.
2004 A4 1.8t Cab
Symptoms
1. 85% of the time pulling away from stationary is a real challenge, the car vibrates and judders and I have to really work the clutch and accelerator to try and achieve a smooth takeaway. There will be the odd occasion where it's fine.
2. While driving slowly if I select 2nd gear and let the clutch out at a normal speed there's a loud metallic slapping noise sounds like it's coming from under the car.
3. When moving backwards and forwards slowly with the clutch at biting point there's a metal rattling coming from under the car. No rattling or vibration when stationary with the clutch in or out, only happens while moving.
4. On the odd occasion when I select 1st gear I don't feel any resistance but I hear and feel a loud clunk.
5. While driving if I dip on and off the throttle there's excessive forward/backwards movement in the gear stick. (suspect this could be snub which I have ordered to replace. Engine hydro mounts already replaced as one was leaky)
6. Sometimes when driving it will seem as though i'm running on about 50% engine almost and if power is now being transferred to the wheels properly.
I've scanned it a few times but no codes thrown.
Thanks in advance
2004 A4 1.8t Cab
Symptoms
Thanks in advance
