Samsellars
- Joined
- Aug 12, 2015
- Messages
- 93
- Reaction score
- 22
- Points
- 8
Looking at ordering the oil tonight will I need more as I'm getting diff and clutch?Here you go this is what I went for
I couldn't tell you that I'm afraidLooking at ordering the oil tonight will I need more as I'm getting diff and clutch?
No worries ill call AMD and check tomorrow as goes in for the work on mondayI couldn't tell you that I'm afraid
Cheers for the insight Alex I think I remember you saying about it on your thread, so not as bad in the dry then? Still can't decide on what route to go down next just going to enjoy it for the momentYou'll enjoy the results.
Just be prepared for the TC and the new diff to fight a bit on wet or greasy roads.
There may be no problem but I found it was better with the TC off,to avoid occasional massive understeer.
Just enjoy it for a bit drive it and work out where you need to work on be it traction suspension powerCheers for the insight Alex I think I remember you saying about it on your thread, so not as bad in the dry then? Still can't decide on what route to go down next just going to enjoy it for the moment
That's annoying did they offer a solution?Amd just rang one bolt on the flywheel has been drilled and tapped on an angle so the bolt won't go in
Waiting to hear back from spec but still 1-2 weeks for a new flywheel, just said do what you can if the bolt snaps or won't go in will have to be a new one. Also needed new diff bearings they saidThat's annoying did they offer a solution?
First problem I've heard of from specWaiting to hear back from spec but still 1-2 weeks for a new flywheel, just said do what you can if the bolt snaps or won't go in will have to be a new one. Also needed new diff bearings they said
They've said its fitted now not sure if they weren't doing something right ect, the bearings should be in tomorrow now so looking goodFirst problem I've heard of from spec
Dunno if amd will bodge it ? But if there reccomending new bearings I'd def do it
Yeah I didn't really doubt them as they've done the same before so just glad it's sorted now reallyCan't imagine they were doing anything wrong,as they've fitted a few of these now,and mine was the first.
There was a problem with the plate on mine,where Spec had fitted the wrong splines,but airmailed a replacement quickly enough.
I put that down to one of those things as the rest of the kit was fine aside from the wrong ARP bolts which were easily sourced.
Yeah, AMD ordered the oil. Hopefully all goes to plan and il have her back tomorrow. Looking at buying a rupes polisher at the momentGood mate glad it's sorted ,
Did you go for a box oil change while it's out ?
Worth doing while it's out and hopefully the slighter thicker oil will offer a bit more protection for the box ,Yeah, AMD ordered the oil. Hopefully all goes to plan and il have her back tomorrow. Looking at buying a rupes polisher at the moment
Got the car back this afternoon, the clutch is awesome and the haldex and lsd really change the handling so much, the added camber at the rear has stopped the rubbing at the back thanks Alex. Just enjoying an evening out driving tonightWorth doing while it's out and hopefully the slighter thicker oil will offer a bit more protection for the box ,
Your love the clutch fella
Nice fella glad it all came together should be a proper weapon you have on your handsGot the car back this afternoon, the clutch is awesome and the haldex and lsd really change the handling so much, the added camber at the rear has stopped the rubbing at the back thanks Alex. Just enjoying an evening out driving tonight
It really is, so planted through the corners now. Definitely no upgrades for a while now hahaNice fella glad it all came together should be a proper weapon you have on your hands
IndeedGlad you like it
Recently added rotiform IND-T alloys 8.5J & RS3 Grill
Think it just clips through the honeycomb mesh I didn't do it so not too sureHow did u manage to get the s3 grill badge on mate?
