A4 oil leak & ariel issue
seany
Hi looked at an 04 1.8t cab 93k 1 owner today cheap money 2k but it has a slight oil leak poss cam seal or cam chain ten gasket? Can smell burnt oil after a drive . Thee radio has no reception & the boot gator has been cut taped back up history say's a garage investigated the issue a few years back guessing wiring fault or amp's in boot lid.
Worth punt or avoid .
Advice asap would be great as i need to tell the guy if i want it.
Thanks guys
Sean
Have a look at the back of the cylinder head regarding the leak but I think it's more likely to be from the drivers side of the rocker cover that's leaking as that's above the exhaust manifold, oil dripping onto hot manifold = burning oil smell. Would be as well changing rocker cover and cam chain tensioner gasket if you buy. Can you scan for fault codes for the aerial problem?
733
517
873
