Don't you get better results sanding headlights with (600)800/1000/1500/2000
Cleaning all residue with Isopropyl alcohol or something similar.
For clearcoat apply 50/50 mix of Minwax Helmsman Spar urethane clear gloss with mineral spirits using foam staining brush.
Despite all they are selling you plastic-x with paint thinner and little bottle of varnish.
3m kit is supposed to be pretty good. I used the old Megs kit (wool pad for the drill and plastic polish and some sanding pads) and i didnt think much of it...
Apparently as Tom says the 3M one is meant to be better and been around longer.
Are there any kits that can used by hand if you don't have a drill to hand?
I used the 3m kit on mine, you could use that by hand for sure.Are there any kits that can used by hand if you don't have a drill to hand?
