Unknown fault codes
dc240969
Member
Ran a check on my daughter A1 1.4 tfsi. Came up with two faults l cant find on rosstech. The are
2 Faults Found:
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 27
Mileage: 62532 km
Date: 2016.03.20
Time: 13:00:28
5673 - ROD - Unknown Error Code
- 00 [096]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
anyone seen these or know what they are.
There was another one but lm expecting its needing a AC recharge or am l wrong
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 28
Reset counter: 93
Mileage: 62263 km
Time Indication: 0
Date: 2016.03.12
Time: 13:01:51
Are you using the most current stable VCDS release? 15.7.4?
Please post up a full scan inside [c0de] [/c0de] tags. Change the 0 to o. Makes reading the scan a bit easier.
Code:
Saturday,23,April,2016,12:02:31:41967
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: WAUZZZ8X5BB099020  License Plate: RACHEL
Mileage: 64050km-39798mi  Repair Order:
Chassis Type: 8X (8X0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 5F
VIN: WAUZZZ8X5BB099020  Mileage: 64050km-39798miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CAXA)  Labels: 03C-906-016-CAX2.clb
  Part No SW: 03C 906 016 BG  HW: 03C 906 016 BG
  Component: 1.4l R4/4V TS H08 8929
  Revision: LEH08---  Serial number:
  Coding: 00190032000401000000
  Shop #: WSC 00046 790 00000
  ASAM Dataset: EV_ECM14TFS01103C906016BG 001006
  ROD: EV_ECM14TFS01103C906016BG.rod
  VCID: 65CA669764C22916ED-8030
2 Faults Found:
  U1025 00 [040] - -
  Freeze Frame:
  Fault Priority: 6
  Fault Frequency: 27
  Mileage: 62532 km
  Date: 2016.03.20
  Time: 13:00:28
  - 00 [096]
  Freeze Frame:
Readiness: 0000 0000
Address 03: ABS Brakes (J104)  Labels: 6R0-907-37x-ESP82.clb
  Part No SW: 6R0 907 379 BB  HW: 6R0 907 379 AH
  Component: ESP8.2i front H07 0001
  Revision: --------
  Coding: 330448E9237600BBCC2512E4C4D100910E00
  Shop #: WSC 00046 000 00000
  VCID: 7F06D4FFEA5E93C607-802A
No fault code found.
Address 08: Auto HVAC  Labels: None
  Part No SW: 8X0 820 045 A  HW: 8X0 820 045 A
  Component: J255 Klima Manuell  0140
  Revision: 0000707S  Serial number: 03030004585584
  VCID: 346CCBD35798809EAA-8060
1 Fault Found:
  Freeze Frame:
  Fault Priority: 2
  Fault Frequency: 28
  Reset counter: 93
  Mileage: 62263 km
  Time Indication: 0
  Date: 2016.03.12
  Time: 13:01:51
Address 09: Cent. Elect. (J519)  Labels: 8X0-907-063.clb
  Part No SW: 8X0 907 063 D  HW: 8X0 907 063 D
  Component: BCM PQ35  M  108 0621
  Revision: 00108 AC
  Coding: 0E000A2FA005F100201841E020000154530B6C0A01CF4922DC0887830045
  VCID: 3D7AEEF7A4D241D655-8068
  Subsystem 1 - Part No: 8X0 951 177
  Component: DWA-Sensor H0  H01 0020
  Subsystem 2 - Part No: 1K0 951 605 C
  Component: LIN BACKUP HO  H05 1501
Address 10: Park/Steer Assist (J446)  Labels: 8X0-919-475.clb
  Part No SW: 8X0 919 475  HW: 8X0 919 475
  Component: PARKHILFE 4K  H03 0011
  Revision: 11001001  Serial number: 37001111001888
  Coding: 000002
  ASAM Dataset: EV_AU210ParkAssis4K 002006
  ROD: EV_AU210ParkAssis4K.rod
  VCID: 030E580F8AB6F72663-8056
Address 15: Airbags (J234)  Labels: 8X0-959-655.clb
  Part No SW: 8X0 959 655 A  HW: 8X0 959 655 A
  Component: Airbag10.41  H04 0008
  Revision: --------  Serial number: 003JJ001ZFRX
  Coding: 30314539303330303034554A305238583053
  ASAM Dataset: EV_Airba1041BPAAU210 001015
  ROD: EV_Airba1041BPAAU210.rod
  VCID: 48948F23F310147EF6-801C
  Crash sensor for side airbag; driver side:
  Serial number: 3554VRB404R0FAMEA0BV
  Crash sensor for side airbag; front passenger side:
  Serial number: 3575HRB404R0HM78D1GM
  Crash sensor for front airbag; driver side:
  Serial number: 3585HRB40530H92248MN
  Rear Impact Crash Sensor:
  Serial number: 3515ZRB405R0H4DQB8PC
Address 16: Steering wheel (J527)  Labels: 8X0-953-569.clb
  Part No SW: 8X0 953 501 B  HW: 5K0 953 569 H
  Component: LENKS.MODUL  014 0140
  Revision: FF010016  Serial number: 20110427200648
  Coding: 1184004000
  ASAM Dataset: EV_VW360SteerWheelUDS A03004
  ROD: EV_VW360SteerWheelUDS.rod
  VCID: 3972FAE7B8FA7DF679-806C
  Multi Function Steering Wheel Control Module:
  Subsystem 1 - Part No SW: 4G0 951 528 C  HW: 4G0 951 528 C
  Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)  Labels: 8X0-920-xxx-17.clb
  Part No SW: 8X0 920 980  HW: 8X0 920 980
  Component: KOMBI  H07 0124
  Serial number: 00000000000000
  Coding: 41DE00
  ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
  ROD: EV_Kombi_UDS_VDD_AU10.rod
  VCID: 7CFC23F3F74888DE22-8028
Address 19: CAN Gateway (J533)  Labels: 8X0-907-468.clb
  Part No SW: 8X0 907 468 A  HW: 8X0 907 468 A
  Component: GAT 4CAN 1L M H04 0083
  Revision: 1C060023  Serial number: 2341C1141600A2
  Coding: FBCF0064000100010153
  VCID: 438E980FC236372623-8016
  Subsystem 1 - Part No SW: 8K0 915 181 H  HW: 8K0 915 181 H
  Component: J367-BDM  H07 0171
  Subsystem 2 - Part No SW: 8K0 959 663 B  HW: 8K0 959 663 B
  Component: J532_DCDCStab  H05 0006
Address 25: Immobilizer (J334)  Labels: 5K0-920-xxx-25.clb
  Component: IMMO  H07 0124
  Serial number:
  Coding: 000002
  ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
  ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)  Labels: 8X0-959-793.clb
  Part No SW: 8X0 959 793 D  HW: 8X0 959 793 D
  Component: TSG FA  H09 0409
  Revision: --------  Serial number: --------------
  Coding: 011E02200101000100
  VCID: 4E98B93B1974CA4EBC-801A
Address 44: Steering Assist  Labels: 6Q0-423-156.clb
  Part No: 6R0 423 156 B
  Component: LenkhilfeTRW  V277
  Coding: 11251
  Shop #: WSC 00046
  VCID: 2F66C4BFEABEA346D7-807A
Address 47: Sound System (J525)  Labels: Redir Fail!
  Part No SW: 8X0 035 223 B  HW: 8X0 035 223 B
  Component: BOSE G3 A1Q3  H04 0040
  Revision: CK004200  Serial number: 00000000001181
  VCID: 3162C2C7688AB5B6C1-8064
Address 52: Door Elect, Pass. (J387)  Labels: 8X0-959-792.clb
  Part No SW: 8X0 959 792 D  HW: 8X0 959 792 D
  Component: TSG BF  H09 0409
  VCID: 4D9ABE371472F156C5-8018
Address 5F: Information Electr. (J794)  Labels: None
  Part No SW: 8X0 035 182 F  HW: 8X0 035 182 F
  Component: RMC Cnct Plus H50 0647
  Coding: 01010001008053070023020103020100010000
  VCID: 3972FAE7B0FA7DF679-806C
  Subsystem 1 - Part No SW: 8X0 919 603  HW: 8X0 919 603
  Component: DU6 Basic  H42 0084
End-------------------------(Elapsed Time: 02:32)--------------------------
839
25
3K
12
3K
3K
