Callum Hill
- Joined
- Mar 16, 2016
- Messages
- 26
- Reaction score
- 0
- Points
- 1
So I finally fitted my Cambelt today, replaced water pump, thermostat & coolant sensor as well. I was a bit unsure of the timing last night so re did it and still seemed to me to be half a tooth out, but I put a socket down cylinder one which showed I was at tdc, so left it at that I started it, first cold start up a bit noisy I guess as I left the top Cambelt cover off, so once warm and cover back on sounded fine left it running for 20 minutes no eml came of. does this mean it has been timed correctly as if I was slightly out ide get a code is this correct?
