CAI Pipe for A3 2.0 TFSI 2005
Ruhel
Never seen a fuel needle go down so fast!
38
Northampton
I currently have my K&N filter on my Golf MK4 GTi (1999). It is connected via a nice steel pipe. Where could I get one for my car?
Also is there any benifit to putting one on? Won't bother if it will have any detranmental effects.
Thank You
Ruhel
Awesome GTI have a good selection. You won't just get the pipe as they all come with a filter on the end.
I use the Neuspeed on my S3 running at 365bhp and 378 ft lbs.
Reasonably priced, well made and no fitting issues.
However, I have changed the filter included to this one and it gives at least 40% extra surface area for filtration. Maybe not needed though as the figures above were when using the standard Neuspeed cone filter.
http://www.autoinparts.com/Air_Filt..._70mm_Inlet_Dia,_200mm_High/product_info.html
You will need certain tools to do the job though as getting the turbo inlet pipe off is tricky along with removing the rear engine cover support bolts.
Reactions: Ruhel
