Not another Nogaro!!!
"Ian - :earthasiaaus: expert of :nogarors4:"
Done :)
nah i think that title belongs to tuffty or bill TBH!!
I already have a suitable t-shirt for me :)
20170912 163014
Reactions: S3 Hilife and superkarl
Finally got all my gauges working!
I think they look awesome!!
Shifting from 1-3 ... can’t push the rest too high hence the early shifting. Shifting just as boost comes on strong... except that first one
Reactions: killfame
Great look, good job!
As far i know (and what i actually did and couple of friends around me) in break-in period it's good to keep the 3000RPM range.. for safety purposes.
I'm just wondering between Prosport premium series with the white needle or go Stack for mine.... one of the last inside the interior things i have to do and can't make decision.
not really the right way to go about it... you need to build a bit of boost and load to help bed the rings in... just don't rev it out...
All setups are different... boost depends on what setup you are using... on some you won't even see boost at 3k...
Should be no more than actuator pressure and give the engine a chance to load up with a bit of boost so it helps force the ring against the home marks... most of the running in is done in the first 50-100 miles... but you keep it sensible for the first 500 at least before changing the oil for synthetic..
Reactions: IPG and killfame
Yes sir, yes sir! my misconception. Well i break-in my engine with my k04 and ye first 500miles we're sensible, it's actually fun because i knew i'm limited so, rev it all the time till 100km/h super fast and stick there.
I’ve been giving mine a chance to both rev to the boost area and also roll out under vacuum. I’ve been told that will allow varied loads and for better ring seating as they need pressure on them to bed in properly. My vacuum is rock steady (fingers crossed it stays that way)
Was out driving last night, some on the freeway, then the rest on the highway hitting that boost onset area + stop start at traffic lights. Still getting g used to the new clutch & habevsralked a couple times. lol
Clocked just over 300km’s!
Reactions: superkarl
Had another busy couple of days!
... and i got a new toy... i'll let the video do the talking. (Sorry ... i know it's a tad long...)
Reactions: superkarl and killfame
I have some big timing pull going on... sad times! BUT lucky I have actually logged the car and seen this before any massive damage happens. Have been keeping things pretty tame for now due to NOT wanting to break the engine...
Screen Shot 2017 10 27 at 52610 am
and i'm tending to lean out as things begin to get a little intense
Screen Shot 2017 10 27 at 52907 am
some other issues
- pretty sure there is a boost leak(s) somewhere as when i was pushing it to higher PSI i would hear a POP just as i let off throttle. Already changed one clamp at the MAP pipe side of the DV which was weak... now just to find the rest!
- i have two small coolant leaks where i've re-used the OEM clamps on the silicone coolant hoses
... i need a dyno tune...
some other issues
Lol, one question - How you run 1000cc without tune? Isn't that way too rich i think that gonna wash your cylinders.
I'm currently waiting mine to start work in progress and when all been finished, i'm afraid to drive mine 10KM to the tuner with 550cc.
It does have a 1000cc file on it. However it was for a smaller turbo so it’s not so when the turbo is ramming more air in and fuel isn’t tuned in to keep up
IDC looks good though so *fingers crossed*
Should pull decent numbers.
I've only just realised who you are :laugh:
That light bulb moment eh???! LOL when first replying to your posts on FB I always thought “must be prawn from ASN”
Reactions: basil brush and Prawn
5858B015 E952 4F06 AD83 BD0C6340193F
Have definitely stayed up waaay too long... but the cockpit is complete.
Reactions: killfame, SamHendry and S3 Hilife
Just need to replace that steering wheel with a joystick and you're ready for take off :yes: #topgun
... I did get a random red oil pressure warning yesterday. Happened while stuck in trafffic and car was idling/rolling forward at low rpm. I was like ????? What is this!!!! Slightly freakin out thinking.... Leaks? Oil spilling everywhere.... but. Nothing of the sort.
After a bit of a rest and car off (for about 10 mins), then on.... all ok???? Mystery....
Hope it's nothing major after all that hard work! Any fault codes? What was oil pressure gauge displaying when light was on?
no fault codes - oil pressure gauge (lucky i had this!) is working and reading ok, with oil pressure rising and falling as usual...
Oil pressure gauge doesn't lie (assuming it accurate lol)
Are you close to mapping Ian?
Dyno tune maybe as close as next weekend :)
Just gotta button up some small things. Mainly that suspect boost leak and wee coolant leaks. Pretty sure I know the engine is reliable after reading this...
C8B9D584 3714 4129 8BE4 A4D784460BA2
Was able to overtake with ease at 120+km per hr and car runs pretty nicely hovering at around 140km per hr.
The engine has been performing strong -the above trip was a drive to Sydney and back where a trip was made up some twisties and along the Sea Cliff Bridge.
D11EBE94 CC4F 4393 898D AD18D59A8B31
... and it looks like I found he source of my coolant leaks. There was an o-ring at the heater core that wasn’t sealing and these OEM clamps don’t match up too well when using the silicone upgraded coolant piping. Switched to a slightly fatter o-ring and worm clamps = no more coolant leaks.
EFD81911 D3B0 4714 B261 1FEF4902D972 D54C23E7 144D 40A0 8C44 4D9DBEC77854
While the intake was out I made this video just for LOL’s and wow’s
... and of course while I was there I saw grease sputtered I typical line fashion a la split CV boot
974C3EA3 A63C 4D1E AD81 2072BDB6EBC0
I also raised the rear a tad - still needs to be a bit higher I think!
3C408AA6 1DEA 4FD7 AD0A 0B694BE39170
Noggie goes in for a proper dyno tune around the end of next week... so I guess watch this space.
Reactions: Erikn89nl, hydro s3, Stuart B and 1 other person
Spoke to my tuner re: fuel (as I can see that with this tune the AFR gauge is shifting toward the lean side of things) - I asked about why it could be doing this and possibility of e85
Some interesting conclusions
- our 98RON fuel is supposedly not actually 98 and more like 95 as it takes it’s sweet ol time to get here then storage then blah blah blah
- going e85 I would HAVE TO change lines to be compatible and increase injectors/fuel pumps. Would 1000cc injectors and an upgraded in tank + DA-31 in line be sufficient? What about the stock lines corroding? Has anyone changed their lines before?
- then there was talk of using a 98/e85 blend which is really interesting! Have not really heard of that before. Can anyone shed any more light on this?
Going this route I was told can help to preserve the lines while upping the octane.
i seen that - that is pure e85 though
which means i would have to go and re-do all of the lines to make it e85 compatible which i CBF
need to get a fuel pressure gauge lol
...which is coming tomorrow :D
A5793E9D 5460 4C81 B1AD C4681E758B38
Fitted a fuel pressure gauge - never actually knew what it was running at before. Now I do.
FAAB3CE9 5F51 4655 9E12 40B29EB704F7
And now Noggie is next in line ...
*fingers crossed*
- nothing breaks
- nothing catches fire
- some decent performance comes from this
Reactions: hydro s3 and superkarl
Explain yourself man!
It's been 22 hours since you hinted at a Dyno session and still no result!
Reactions: IPG
LOL
tuners will have it for a few more days and will update me as and when things happen.
i'm holding as tight as you are sir!
4.2 l/100km? how on earth?????
It’s not correct as it’s not been adjusted in the map. For the injectors.
So. Tuning had to stop for the day.
F350EA95 3E18 4F2E 9855 C4B4249AD0CC
The one and only coolant flange that is not included as an aluminium part BROKE!!! Coolant everywhere - dyno stopped and many frantic messaging to try and get a replacement.
6B9AC078 DD8B 48C5 92C2 AE2A2F790003
Does anyone know if you can get that one in aluminium?
Luckily. When I finally got home from work and had a scrounge ... this off a BDE
2968AC9E F7E0 41C0 8B94 587A9B04DA44
So I rushed back to the shop and dropped it off hoping one has stolen it and the 3/4 bottle of ready mix coolant (had to leave it outside as they’d already locked up for the day) - for things to move on when they open up again.
at least you know they are trying hard as you have driven it around for 800KM without a fault and they have popped a coolant flange in a couple of runs, is that literally because at 7000 RPM the water pump is really shifting?
Do we have a sweep stake? 540BHP ?
looked risky parking you beautiful S3 near another car on a dyno - especially after watching some of the dyno failures videos on you-tube.
LOL
Go on then. Sweepstake on.
You guess 540!!! Wow. I wish.
I was going to say I’ll be happy with 400-450
That popped on base map file #2 LOL
So yes. They mustve been running it hard yesterday. I’m guessing the outside temp of 32 degrees didn’t help...
there's a few stroker engine's on here over 500 isn't there?
Reactions: IPG
Dropped in to see what was going on.
Wasn’t expecting them to be running in AWD more but I guess that’s the way they do things here downundah
Still on base map... TB hose keeps blowing off
858
31
6K
90
15K
