Chrisz
Hello everyone,
I have an issue with the trunk. The car does not recognize that it is open.
I changed the microswitch/trunk lock, but this didn't solve the issue.
The microswitch seems fine, when I close the lid it closes the connection between the two cables and when I open the lid it connects the two cables.
There is a white/yellow and a brown cable coming from it.
The white/yellow cable I checked, it seems fine (opened a trim in the front of the car at the driver side and measured it with another white/yellow cable if it had any resistance and it didn't).
But does someone know where the brown cable is supposed to go? When I measure it, it seems to be ground, is that supposed to be ground?
Thanks in advance, hope someone can help. Spend hours and hours to find out what's causing this!
