http://www.jbsautodesigns.co.uk/news/4/new-jbs-k04-oem-upgrade-cast-manifold
Im bricking it as I know my Pro4 is a ticking time bomb
OK.
I know you can buy the manifold direct from the supplier that Bill used to get them from, but he doesnt have time to port them now does he?
Is there anyone else in the know that would port one ?
I ported my standard k03 manifold and k300 hot side myself without too much bother... Just ordered a few different carbide burrs and used them in a drill, making sure I kept them lubricated with WD40. Once enough metal was removed I then went over with a dremel type tool (from lidl) with a sanding wheel to smooth things off a bit.
this is such a good thread!!!The chinafolds are hard as nails which is the main issue... makes them durable but a ballache to port...
There is a thread on vortex of someone porting a JBS one to get over the original misfire problem...
http://forums.vwvortex.com/showthread.php?5675749-The-JBS-K04-manifold-reworked/
Sell the TTE turbo, buy a B5 ko4-380 package then you can have one
He got the bbt k418t not the ttePossibility like ! im sure Bill takes the K418T in as exchange?
Backwards step surely?
And why would that be?
The OP has a BBT turbo by the looks and not a TTE anyway...
The TTE is a amazing turbo, Since the lad actually has the BBT hybrid, which isnt based on the TFSI variant, then the comment is pretty much null/void. Bit hard to compare a 1.8T k04 frame to a TFSI k04 frame as they leagues apart.
-6KW would suggest its choking. -6KW with meth too? Hope that never fails as that ECU will be well into knock otherwise.Not anymore they are not...
http://www.audi-sport.net/xf/threads/new-aet-badger5-k04-380-402bhp-dynod.266800/
