RNS-e Bluetooth disapeared
Slvravnt3.0
Greetings all. Hopefully someone can help me out. I've searched high and low and cannot find anything related to the problem i'm having. Just installed a bluetooth module yeterday. After the proper coding everything was working fine except for the DIS. Today I got in the car and there was no bluetooth found. I tried resetting the unit by disconnecting the plug for a few minutes twice and reset the RNS-E and still nothing???? Can someone point me in the right direction, please and thank you.
2002 A4 Avant 3.0 6 speed no bose no MFSW
The RNS-E is a 8E0 035 192 D
The bluetooth module is a 8P0 862 335 T
Current coding is
STG56 0309611
STG77 0010307
ch62 is 23
All is well now, problem solved. had to redo the coding. The #77 code is now 0010707 from 0010307. The RNS-E in the B6 A4 works on K-line instead of CAN and neglected to see that while doing the original coding. Still dont understand why it worked initially though. Also had to change the #56 code to 0301613 because I was getting a 01044 fault that control module incorrectly coded. The dension gateway ipod adapter is seen as a cd changer so it was throwing a fault code and also dont have bose so fixed that too.
852
