Silver project top mounts
Grale1
Redhill Surrey
Hi guys, I've had a set of these adjustable top mounts sat in my garage in there box for a year or so. It's got to a point where my car tracking is really bad and just all over the show. I'm going to be fitting them asap but anyone who has fitted them have you left on the oem bearing that sort of sits under the rubber top mount? Or are they just not needed?
Any help is much appreciated
Si
Use the bearing, should look something like this:
http://www.audi-sport.net/xf/threads/prawn-and-bigals-a3-track-car.109831/page-77#post-1736656
As above ^^^
The rubber top mount goes, but keep an oe bearing in there to prolong the life is the spherical bearing.
You'll need them setting up and a full alignment doing once there on remember. If you don't plan to do this straight away try and position the shock pin dead centre on the mount in the interim.
Cheers guys, much appreciated that.
The car needs these fitted so I can get the alignment sorted as its all over the show.
876
10
5K
859
