Hi want to get more power out of my a5 2.7tdi and input on this thanks
A5DRS Registered User Joined Jul 6, 2016 Messages 10 Reaction score 0 Points 1 Jul 24, 2016 #1 Hi want to get more power out of my a5 2.7tdi and input on this thanks
bobby singh BSR VCDS Map User Gold Supporter Joined Jan 21, 2013 Messages 1,333 Reaction score 1,245 Points 113 Location West London & Windsor Jul 27, 2016 #2 What turbo does it have? 1756?
A5DRS Registered User Joined Jul 6, 2016 Messages 10 Reaction score 0 Points 1 Jul 28, 2016 #3 Not sure sorry
bobby singh BSR VCDS Map User Gold Supporter Joined Jan 21, 2013 Messages 1,333 Reaction score 1,245 Points 113 Location West London & Windsor Jul 29, 2016 #4 If you can get the turbo details and what hpfp it has then you will have a better idea of what can be done. 1756vk can do 265hp / 600nm
B BIGA3T Registered User Joined Jul 21, 2012 Messages 227 Reaction score 13 Points 18 Location NULL Jul 30, 2016 #5 bobby singh said: If you can get the turbo details and what hpfp it has then you will have a better idea of what can be done. 1756vk can do 265hp / 600nm Click to expand... i have the same car, you think its worth it for me to get the gtb2260vk from the a5 3.0 tdi ? or just remap my current setup? ive ordered DPF downpipe bigger inter cooler from wagner and will be doing straight through exhaust no cats or dpf
A adamss24 Registered User Joined Jul 3, 2007 Messages 4,543 Reaction score 412 Points 83 Location London Jul 30, 2016 #6 You need to watch EGT with the grb1756vk, a gtb2260vk will be nicer to drive and would not abuse your clutch as much as it's little brother...
bobby singh BSR VCDS Map User Gold Supporter Joined Jan 21, 2013 Messages 1,333 Reaction score 1,245 Points 113 Location West London & Windsor Jul 30, 2016 #7 2260 would be nicer and good for around 320hp. Like i said you should see what pump is fitted.
